Twin socket fitting on towbar
  • Twin socket fitting on towbar
    Hello
    I've read how to fit the towbar and single electrics from this link.
    http://www.showmesome.info/hilux/workshop/towbar.htm
    Can anyone advise how a double socket is fitted with some photos / description on where the wiring is routed to the battery at the front?
    Mark..
    WHY! Have you bought one now mate
      All being well, should collect the Surf next week. So the first job is to fit a towbar and a twin socket would leave all options open.
        Originally posted by papacroft
        Hello
        Mark..
        don't know the "proper" way, but i'd go through the bulkhead into the cabin, then under the carpet into the boot, then out through the boot floor, then you also have power in the rear of the car for other stuff (jump starting, cool box, work lights etc.
        i've got a 12v lighter socket and some spotlights running off mine (used the power cable to my amps)
          Loads of info here.
          Rich.
          http://www.rydertowing.co.uk/pages/d...lGuide2003.pdf
            If your running a double socket for charging a caravan battery/running a fridge whilst driving etc. you'll need to fit a relay that cuts in when your Surf is charging, do you have the kit or do you need to make one?
            ...Woodie http://woodie.pwp.blueyonder.co.uk/D...%20Surfsml.JPG
