ECU/IG Fuse
  • ECU/IG Fuse
    Anyone know what the 20Amp ECU/IG fuse in the attached pic is for. It can be removed and the vehicle still starts and everything else seems to operate normally.
    Nev
    Scanner isnt working but the owners manual I have lists it as
    ECU-1G 20A 2 Stage Shock Absorber
      Thanks. After you reply and some testing it is indeed the fuse for the Hard/Soft setting on the original adjustable shock absorbers.
      Nev
