O...K...
In your diagram, when in the fan off position, there is a positive feed through off bulb (which is what you want), but, according to the diagram, there would be current flow through the override bulb to earth. Assuming the bulbs are of equal wattage, each bulb is only half as bright as it should be as there is only 6v across each. The relay coil appears to be in parallel with the override bulb. Whether the override bulb does or doesn't illuminate in this case would depend on the resistance of the relay coil (and automotive ones tend to be fairly low resistance compared to say, communications relays) as a lower resistance coil would tend to consume the lions share of the current.
Still, what you have works, which was the point!
Popping a diode in between the
