Hi I have just changed my surf SSR-X GEN3 for a SSR-G and I found that my rear heater does not work can any one tell me the most likely thing to check and were. I have checked fuse and that is ok.
the rear heater is fed hot coolant via narrow bore pipes on the underside of the car.
If the heater hasn't been used in a while, can easily clog up. Usually flushing through with fresh water works. Can't quite remeber where the hoses are in the 2.4, the hard pipes on the underside are easy enough to trace though.
