I've got my eye on a 24 volt accessory, does anyone know if there is such a thing as an inverter that can be used to supply 24 volts please?
24 Volts
Check the current required.
10 A at 24V = 20 A at 12V, plus inverter losses.
The Surf electrics may well be up to the job, but I'm not sure what fuse they put in the cigarette lighter line. If it's less than you need, don't just change the fuse, use a separate connection from the battery or fusebox feed (make sure you add a fuse to the line).
