Dont use the cheap plugs you buy in halfrauds i mean the red and black plugs they are useless and tend to go brittle when they have had a fair amount of current run through them
Thanx for advise. Any suggestions for a source of an item suitable to handle half a dozen 3700 MAH batts at 4 amps in one afternoon? I CURRENTLY "could not RESIST that" pop the bonnet and connect to the surfs batts.
Definitely a great source for all your electrical bits.
I would go for DIN power connectors, they aren't very deep, it should be possible to fit some sockets discreetly under the dash and leave your ciggy lighter free.
