Hi,
So I've been having rael bad problems with my electric windows and Central locking...
Previous owner installed his own alarm and made a right hash of it... seems he's damaged 2 wires on the electic window circuit. Because the loom was so tight I decided to replace the wires which worked fine...
But with all mt fiddling about I think I shorted the Window Control unit... and I'm hoping that I blw a fuse or popped a CB.. Thing is I can't find the fuse any where.
The Haynes manual isn't much good, its hard enough figuring out the wiring colours with no key let alone the location of items.
I've looked in the usual places... behind the right hand kick plate.. Engine compartment etc etc...
Any help and suggestions much appreciated.
Thanks in advance Snapper
