rear lenses
  • rear lenses
    How do you undo the lens to get at bulbs, and in my case
    replace a cracked lens
    Drop the tailgate down and there are two bolts on either side to remove the lenses.
      good
      I was hoping this part of the answer actually
      had visions of taking out the interior to change a bulb
        Once the bolts are out you need to ease the lens towards the outside of the truck (ie not rearwards away from the truck but to the side. There are two rubber grommets holding the lens on and it takes a little pressure to overcome their grip).
        Hope this helps.
        If you're gonna have one ...... have a good'un!
          broke
          Well it's my fault I managed to back into the gate post,
          when I'm forever telling the wife not to crash into it, still
          Our friendly surf breaker here, has once again come up trumps on the parts front, and it should be winging its way here as I type
            Back will look like this.
            http://groups.msn.com/toyotasurf/nif...o&PhotoID=6687
            Nev
              lens
              do you remember how the lens comes off the bulb housing itself
              by any chance
                Do you mean seperate the coloured lens from the back half?
                I don't think you can 'cos they're bonded.
                  oh, right!
                  I haven't looked at unit to closely, just ordered used one,
                  thinking it would be a lense only.
                  so a complete moulding that just slots the bulbs in, is better still
                    Yep. Lens and body all moulded together as in pic.
                    Nev
