Fuse? Electric locking and Electric Windows
  • Fuse? Electric locking and Electric Windows
    I would be grateful if anyone can help with the location for the fuse that covers the electric locking and electric windows?
    Thanks
    Tim
    Thanks
    Tim
    hi tim try the drivers side footwell or drivers side under the bonnet
      Thanks
      I have looked in both of these places but none of the labels on the fuses covers these extras!
      Tim
        Thanks
        Tim
        the only other thing i can think of is to just check each fuse in turn to see if one of them does the door locks.just looked at mine and it does'nt state which is for the locks either,so if you do find it ,it will be handy to know for further ref.
          Thanks
          Tim
          Found it!
          The fuse is a 30A ( pink square type the same as the 30A middle fan one in the engine compartment small fuse collection). The location is in the footwell ajencent to the fuse box. Look upward there are a collection of relays plus the additional fuse. You will need a torch and a supple back to get into position to find it!
          Hope this helps anybody else with this problem
          Tim
            My handbook says fuse 5 in the footwell.
            Covers Gauges, reverse lights electric door locks and power windows.
            Fuse 5 is right in the middle of the block of 9.
            It just does, OK?
              cheers dave
