relay clicks when brake pedal pressed
  • relay clicks when brake pedal pressed
    Hi,
    did 526 KM's today (wolverhampton, and a bit of birmingham and back)
    On way back the truck starterd to "click" This is a relay that is switching when the brake is pressed. It stopped around Burnley and stayed away until I got back to Ilkley when it came back again!!!!!!!!!!! I seem to have both brake lights working. Any ideas folks
    Al.
    I used to have a surf me!
    I know mine clicks to 'unlock' the gear lever. Is it the same 'click'??
    It just does, OK?
      mine does not normally click dunno what the reason is but I can get mine out of gear without pressing the break!!!!!
      It is clicking now intermittently as I drive it wwhen gear lever is in D!
      I bet this is something to do with it. Thanx for the response. anyone come back with more on this gear lock thing and the poss cause?
      Al.
        OK, a bit of a shot in the dark, but how about a dodgy brake light switch?
        It just does, OK?
          don't think so as the lights work just fine. I rtecon you were on the right lines with the gear release. I am gunna have to look at this first. Will post to let you kjnow what the problem is/was.
          Al.
