no lights on heater controls or cig lighter
  • no lights on heater controls or cig lighter
    i removed part of dash to fix heater today this worked by jiggling the nob made the blower now though ive lost the background lights on the hot cold and heater settings also the cig lighter are these on a fuse together i may have blown or have i dissconnected something please let me know before i take it apart again matt
    funny you mention this
    mine heater control back lights have always been dodgy.
    meant to come on when headlights on, but often they wouldnt.
    i found if i pulled the blower direction or any other control sharply both ways, they woudl come on!
    now they dont come on at all, annoying when driving in dark and cant see the controls
    any ideas anyone?
    Landcruiser Colorado
    Sub. Forester
      There is a small multi- plug in the back of the heater control, perhaps this is loose as it doesn't 'lock into place, just a push fit.
        cheers Bushwacker - will check it out
        but may take me a while...
        took me 3 hours to fit 4 new shocks last night... had to take angle grinder to back ones - as rusted at top nut, was a challenge to even angle grid the sods
        Sub. Forester
          where can i get these bulbs?
          bulb behind heater control unit blown
          as is one in ashtray
          same bulb as cigarette lighter one
          where can i get these bulbs from? are they a standard item at motor factors or toyota specific?
          Sub. Forester
            You should be able to get them from any motorists shop, they're tiny glass bulbs with no base on them, just the glass bit. They just pull out, and push in.
              Techy name is 'capless' bulb . My old girl needs a thump on dash to get heater illumination on . Same as an old Sierra I used to own .
