rear window help!
  • rear window help!
    Hi there, im a newbie to my surf (LN130) and the back window goes down great, but coming back up it seems a little hesitant about half way up, almost like the power supply is struggling??? im not to sure what it is, any ideas??
    Thanx in advnace, Don
    LIVE TO WIN, DARE TO FAIL!
    Hi yer m8ty.
    with the window down clean the window rubbers to get all the old
    crud out, screwdriver ,bit of rag and some white spirit/degreaser
    type stuff. Use a silicon spray for window runners ( halfords )
    a good spray up clean any excess off and give it a go.That
    should improove it,if not you may need to grease up the window
    mech.in the tail gate, take off the carpet bit, unscrew the
    cover plate,shut the tail gate wind up the window and from inside
    the truck you can get to the cogs etc again use silicon spray.
    Hope that will help, if not give a shout
    GOT NO COWBOYS HERE?
