can anyone help with the handbrake warning light? It comes on bright when handbrake is applied and only dims when handbrake is taken off ........i have checked pads and brake fluid reservoir and all seems well ...
brake warning light
Disconnect the terminal for the wiring to the low fluid sensor on top of master cylinder and see what happens.If the light stays off and fluid level is ok and handbrake switch is adjusted right along with vacuum system working ok then the sensor is faulty.This is a very common fault and mine is the same.
Neville
