Has anyone ever fitted one of the rear spoilers with the integral high level light. I would appreciate any advice re the wiring and how to get the interior trim panels off without damaging anything.
If you remove the plastic trim which holds the load area light, you will find a connector with orange and white wires, (If I remember) this is the connector for the high level brake light.
As for removing the rest of the trim................. http://www.showmesome.info/hilux/workshop/rear_trim.htm
