Hi folks hope somone can answer this. Brake warning light has recently decided to stay on permanantly (dim) Fluids good, new pads and bulbs not blown? any ideas
If you unplug the connector for the low fluid warning switch and everything returns to normal then this will be faulty.Mine is and is now disconnected permanently.Just keep an eye on fluid level if you do and decide not to replace.
