The attachment below is what you see when you have pulled out your old Toyota radio. Anybody know what the unused block is for as it wasnt plugged into the old radio which was unbelievably basic with AM only.
Radio wiring question
um... yeah... could be!!Originally posted by popbriscoei thought it was for cd changer
just thinking that orange is usually electric aerial
yellow is +ve
but yeah they could be the +ve and the remote on for a cd changer!
or japanese confusion tactics! like vauxhall having brown -ve (german idea i'll wager!)nee nar nee nar, i'm a fire engine!
that what Geezer told me in car electrics place in town here.Originally posted by dabigmanum... yeah... could be!!
yellow is +ve
or japanese confusion tactics! like vauxhall having brown -ve (german idea i'll wager!)Enjoying Life after Cancer
Pops
Originally posted by JimLThe attachment below is what you see when you have pulled out your old Toyota radio. Anybody know what the unused block is for as it wasnt plugged into the old radio which was unbelievably basic with AM only.
Jim same as mine, your unused block was the one connected to my cd player, so now unused on mine. Got a lead for toyota motors that plugged straight on to the radio block on the surf and the other end onto the block from the new radio.
hope this helpsSay not always what you know, but always know what you say.
My 4x4
My choice
Back off
Check out www.installdr.com for details of the wiring.Maurice
When you get your new stereo, nip into Halfords (or and audio place if you know one) and ask for a converter lead that will turn the Toyota loom into the standard iso system. It will have all the conversions wired in so the new unit simply plugs in and saves all the scotch lock and tape marathon that you used to have to do. It will probably use both plugs in your picture.
My local Halfords had one for my 2nd gen on the shelf.
Phil.
The unused block is the power supply to a woofer speeker amplifier that was an option.Originally posted by JimLThe attachment below is what you see when you have pulled out your old Toyota radio. Anybody know what the unused block is for as it wasnt plugged into the old radio which was unbelievably basic with AM only.
The drawing is here:
http://www.afm15.dial.pipex.com/surf...oundsystem.jpg
Rich.If life's an uphill struggle then downhill from now on can't be that bad?!
Autoleads would be a better betOriginally posted by Phil HWhen you get your new stereo, nip into Halfords (or and audio place if you know one) and ask for a converter lead that will turn the Toyota loom into the standard iso system. It will have all the conversions wired in so the new unit simply plugs in and saves all the scotch lock and tape marathon that you used to have to do. It will probably use both plugs in your picture.
Phil.nee nar nee nar, i'm a fire engine!
BRILLIANT !!!Originally posted by MorrCheck out www.installdr.com for details of the wiring.
: click on favorites:
: click on add :
You de man Maurice
** according to this link, the unused block is for rear speakers which I dont have **Last edited by JimL; 19 November 2003, 20:51.
Yep I've checked. I have the whole inside rear corner trim off and I can almost put my head in the hole to see behind where the speaker should be. I have a habit of taking things apart and not putting them back together again for 6 mths. I also have half the dash removed since July and you can look at the inner workings of my rear window while I sit in traffic. The carpet cover that clips onto the inside of the tailboard blew off my shed roof last week in the stormsOriginally posted by high-surferhi Jiml
Have you actually checked to see if you have no back speakers. It may be that the amp just has no power going to it. If your fitting a sony head unit then you have to do a slight mod to the adapter you get to power the back amp.
