Any chance of someone posting a diagram or pic to show me how to wire the fog lamp into the rear light cluster(legally)?Cheers.
Fog lamp mod
If you have a high level brake light then this can be wired (legally) as a fog light but the feed maybe a bit more difficult to route!Originally posted by RobDAny chance of someone posting a diagram or pic to show me how to wire the fog lamp into the rear light cluster(legally)?Cheers.
It's a case of getting in there and undoing things!
EDIT
Actually that is bollox cause it cant be more than a metre from the ground so the spoiler ones are out!Last edited by rich; 17 November 2003, 10:12.If life's an uphill struggle then downhill from now on can't be that bad?!
i'm gonna go measure the mondeo for this 100mm foglight thing.... i'm sure the're right next to each other?Originally posted by richIf you have a high level brake light then this can be wired (legally) as a fog light but the feed maybe a bit more difficult to route!
EDIT
Actually that is bollox cause it cant be more than a metre from the ground so the spoiler ones are out!nee nar nee nar, i'm a fire engine!
Nah,
They'll be at opposites with reversers in the middle.
Originally posted by dabigmani'm gonna go measure the mondeo for this 100mm foglight thing.... i'm sure the're right next to each other?If life's an uphill struggle then downhill from now on can't be that bad?!
You'll probably get away with it on the 3rd gen then.
Originally posted by dabigmanon the surf they're
FOG/REVERSE
INDICATE
STOP/TAIL
so there is a gap at least!...
i'll worry when it comes to MOT time!If life's an uphill struggle then downhill from now on can't be that bad?!
