4Runner Alarm / Immobiliser
  • 4Runner Alarm / Immobiliser
    Does anyone know how to reprogram the alarm fobs off my 1995 4Runner. I've been told that the alarm is a Scorpion Alarm, who unfortunately went bump about 2 months ago. I've attached an image if that helps.
    Many thanks
    Many thanks
    i dont mean to sound daft but have you checked the fob batt as this will stop it arming if it is low or flat.other than that if you turn the ignition on till all the dash lights come on then press the arm button turn the ignition off and that should do it(hopfully lol)
    I HAVE FOUND JESUS he was behind the sofa
      Thanks Kiowa,
      batteries replaced etc. tried the method you suggested but to no avail, guess a new alarm immobiliser will have to purchased unless anyone knows any different things to try.
      Thanks,
      hulmena
        sorry it dident work bud the only other thing i can suggest is popping into a place like sextons or a car audio shop that sells alarms and see if they can help
          Many thanks
          Hi
          Try taking off the earth leads off the batteries or the fuse out of the alarm, then after about 2 minutes put it back on then press your remote within 10 seconds and if they are universal remotes that should do the trick.
          (Have you got 2 remotes ??)
          Steve
            Originally posted by steve.keley
            Hi
            Steve
            Yes, got 2, none work.
            Neil
              Neil
              Have you tried resetting the alarm Eg:taking off the battery earth leads
              Steve
