Any Suggestions?
  • Any Suggestions?
    My Rear Window has suddenly decided not to operate via the Switch on the Centre Console - it still operates normally via the key in the Rear Door. I had a look at all the Fuses and they're fine. The wiring to the Switch also seems to be in good order - can anyone help?
    Better to be in Cumulonimbus than Cumulogranite
    Check the window lock out button on the drivers side window switch panel, probably pressed it by accident.
      Andy, you're a Star!! I never realaised that switch affected the Rear Window! - however, considering it says "Window Lock", that should've been a bit of a give away!!
