turning reversing light into fog light ??
  • turning reversing light into fog light ??
    I've read that a couple of people have done this already.
    Am i right in thinking that you use a reb bulb in place of the white bulb?
    And use the existing rear fog wiring (if its present) ?
    and will this pass the SVA?
    any help appreciated....
    [CENTER][img]http://www.danasoft.com/sig/bolloxx.j
    Bl***y hell, had me checking my IP address.
      hehe cant fool me with that
      I havent used IE for ages!
      Tim
        Well he's nearly got me. That looks like a server belonging to my broadband supplier.
        62.252.192.17 resolves to, manc-cache-14.server.ntli.net. Anyone got any good hacking tools.
          hehe... dont worry about the signpost fellas...
          it can only be read by you on your machine....
          like a local reflector of your info....
          Anyone got any ideas about this lighting problem??
            I think you might get away with it for an MOT but probably not an SVA. Something to do with it being E-Mark approved. Sorry I can't remember owt else about it.
              I have this set up on mine with the rversing light. It can into the country like it i believe and passed the sva and mot. This has been said before but its a case of pot luck.
              I always work better wet .
              Its why I became a plumber!!!
                Try checking here: http://www.showmesome.info/hilux/workshop/foglight.htm
                Alternatively I have gone for an in bumper fog, this can also be found on the same site if you have a look around.
                Rob & Miranda
                Surfing on the south coast
                  Thanks for the replies fellas... sorted now
                    Has anyone tried using the third brake light as a fog? This is already red and is also 21watt. It's what I'm thinking of doing
                    Cheers,
                    Sean
                      Think there is some law about height of fog light from ground for MOT
                      Mine is in my reverse light but done way after the SVA (wouldn't advise any mods until SVA is passed)
                      [COLOR=Red][FONT=Century Gothic]the unexamined life is not worth living...[/FONT][/COLOR]
                        Do you know how much it is to put a fog light in the bumper? I am fed up with having to keep replacing it.
                          just a note but the fog light must be on the off side for an mot.
                          so much to do , so little money , so little time
