Hi my front washers dont work and if i press the washer i dont think i can hear anything, is it a motor problem or is there a specific fuse for the front washer as my rear works fine..........................  ......
Help on windscreen washer please
If yer 'bidet' works, then it must be a blockage, either in the jets or the tubes.Originally posted by ukvihaHi my front washers dont work and if i press the washer i dont think i can hear anything, is it a motor problem or is there a specific fuse for the front washer as my rear works fine.......................... ......
