I fitted a Towequipe towbar to my 2nd Gen Surf at the weekend - very well made and easy to fit.
Now I know it's been covered before - but I'm still a bit confused
 when it comes to the wiring.
From what I can work out from using the search tool on here, I'm I right in thinking that it's just a matter of running conntections/wires between the main towbar cable and the corresponding various wires in the rear light clusters?
The towbar also comes with a an audable alarm (which I'm told has to be fitted - by law). Do all the componants run to this box (as it seems to have a number of wire coming out of it) or is it just one connection?
The electical instructions are a bit vague
Want to have a crack at this myself if I can.
Cheers,
Paul
 when it comes to the wiring. From what I can work out from using the search tool on here, I'm I right in thinking that it's just a matter of running conntections/wires between the main towbar cable and the corresponding various wires in the rear light clusters?
Cheers,
Paul
disco now gone aswell
