Electric mirrors
  • Electric mirrors
    I've just bought a '93 SSR-V 3.0 and the electric mirrors don't work. This seems to be the only electrical item that doesn't work - is there a fuse just for this, any obvious things to check first before I pull the door apart.
    this seems to be a common thing no one seems to know why apart from check that the connection is correct on the back off the switch . theres alot of surfs out there with non electric mirrors. sorry
      This is not a common problem ?? Have you moved the slider across to select which mirror you wish to adjust.
        between looking at it and picking it up the monkeys at the garage managed to blow the fuse to the mirrors, also linked to the radio and clock on mine. Might be worth a check
