I'm looking at putting some driving lights on the front of my surf, I found some 130w bulbs to put in them and realise this will need substantial wiring and relays etc to handle the current. With 2 x 130w bulbs I work that out as 21 amps through the relay, so I figured a fuse rated at 30 amps and relays and wiring rated at 40amps ought to be plenty strong enough.
I am quite happy these figures are right but when it came to buying the bits the fuses on vehiclewiringproducts.co.uk have 2 ratings continous and fused so do I want a
30 amp continous (fused 60amps) fuse or a
15amp continous (fused at 30amps)?
Thanks in advance
Darren
Thanks in advance
Darren
Nil Illigitimi Carborundum
