just gone to fit a second battery but only have the positive clamp to fit to it,should there also be an earth and if so where does it connect to.(i will have to make an earth lead up if mines missing)
battery
You should have an earth lead on the second battery aswell, it earths to the inner wing at the side of the battery.Originally posted by freemanjust gone to fit a second battery but only have the positive clamp to fit to it,should there also be an earth and if so where does it connect to.(i will have to make an earth lead up if mines missing)
THE ORIGINAL CRAZY BITCH!
Earth Lead
THANKS FOR INFO I WILL MAKE ONE UP AND FIT ON WEEKEND.no need to make one up found it hidden behind washer bottle jobs a good unOriginally posted by crazybitchYou should have an earth lead on the second battery aswell, it earths to the inner wing at the side of the battery.
