I have the same problem...cannot open the back window with the key.
So I checked for the relay in the back side panel but I only found disconnected wires and no relay (maybe previous owner took it out)
I've got a brown, pink and blue wires. Also a black and white wire wrapped in a grey one.
Can somebody tell me which relay I should use ie;to buy and which wires connect to the relay???
Any help is much appreciated.
David
David
 Nil Illigitimi Carborundum
