remove the interior roof trim? Ive just bought some roof marker lights off e-bay and i want to know how i get access to the wires when i drill the roof? Anyone done this before?
How do i.........
Where do you want to mount these lights...
If your arms can bend in quite a few places, or you are comfortable like that...
sun visors, grap handles, rear view mirror, door trims... central interior light...
gently ease the roof lining down, there is a roof skin brace which the sun visors and rear view bolt into... you can spiral wrap your wiring and jam that into there...
Not a nice job, and be careful the roof lining is strong (read rigid), but its not that strong, and if it is going to crease, it will crease around the centre interior light...
andyL
andyL
There isn't much room under there... you might want to take the roof lining out completely... and that is a pig.
Order yourself some of the grey clips that hold it up in the load space (you will most likely break them), and remove all the trim on the sides of the interior...
then when you have the grab handles off, and the upper rear seat belt points... it'll "just" slide out... you'll need second pair of hands here... and somewhere to lay it down flat...
andyL
