white dials red and black ?
  • white dials red and black ?
    fitting the dials now but not to clear on were to wire in.
    followed andylala and dirtydog instructions (big help cheers) but not to sure about tapin into power source.
    i think. using big blue clip red to secound wire green and black to first wire black/brown ?
    not to good on elecy jobs.
    come to think about it not to good on mechanical either
    I metered out the first wire on the connector as the illumination wire, so +ve (red)
    Fourth wire along on the connector is an earth wire, so -ve (black)
    Make sure you have disconnected both batteries first... don't want to short anything out.
    Check out the image. See the red wire taped into the first cable out of the connector, surf side... (blue connector)
    Note: White side connector is the ISO adapter to them plug the stereo in.
    HTH, andyL
      cheers for the quick reply fella
      the tec connector is the big blue one?
      but were is the connetor for the red wire thats what i've been looking for.
      sorry for going round in circels dude.
        i did mine on the blue block behind the instrument cluster, i connected the red wire to the green wire in the blue block (2nd in on top row) and the black wire to the white wire (1st on top row next to green).
        didnt connect my battery but i only scotch locked.
        good luck mate
        Tim
          nice one dude.
          i'm off to blow my self up now frizzeled hair the works.
          cheers fellas
            Ok. standard fit in a 1991 LN130W is blue connectors... surf side
            The ISO adapter that mates to these connectors splits into two black connectors.
            This blue connector is the one that feeds the head unit...
            New image of the blue connector.
            Notice the orientation of the connector, with the key in the bottom row, first cable moving left to right and forth cable.
            First cable Green based is the illumination cable (goes live wihen you turn the lights on...) Brown based cable is an earth...
            Red light from inverter goes to the green cable, black to the brown...
            Hope that is clearer...
            andyL
              just to confuse you i was talking about the blue connection block behind the instruments... see pic above, unless its too late!
              Tim
                Ahh, understood. Just prefer to use one I can get to easily if there is a problem...
                Sorry, I didn't meter out the one on the cluster...
                andyL
                  SUCCESS everything working no fire no shocks.
                  cheers for the help
                    BONUS!
                    Tim
                      Good job, well done.
                      andyL
