1990 Surf, imported from Japon, has a flash Panasonic radio/tape/12 stacker. Also has a screen approx 3inch by 3inch and a 'TV' button.However if the button is pushed the elec aerial goes down. Any help about the system would be great. No-one here has seen anything like it!
Surf's Panasonic TV!?
The TV won't work over here, uses NTSC format.Originally posted by Muzz671990 Surf, imported from Japon, has a flash Panasonic radio/tape/12 stacker. Also has a screen approx 3inch by 3inch and a 'TV' button.However if the button is pushed the elec aerial goes down. Any help about the system would be great. No-one here has seen anything like it!
I'd get rid of it and put a UK spec Stereo in it. You can get them converted but it's expensive enough to not be worth it.
He is in New Zealand. They might have a different format.'94 3.0TD SSR-G Limited Green over Silver, mmmmmmmmmm!
