hi, I am about to wire a set of wipac lamps on my 3rd gen hilux. I previously had a hilux 4 cab & fitted a pair of cibe's all wired correctley with relay & switch, the relay taking its feed from main beam. All worked well apart from the cibe would work when I had side lights on! Weird! I checked the voltage and there was a current going to relay  from main beam circuit
Is this because of the negative switching?
I am about to wire the wipacs in so any help would be much apreciated
cheers
cheers
