Hi all,
Yep turned on the rear window heater this weekend and nothing happened
Read all the posts, went out armed with screwdrivers etc and took the back panel apart.
Wires were off the connectors so thought I had fixed the problem when I re-connected them.
Unfortunately not.
I am getting an earth, but no live feed to the window.
Wound the window up and down until the micro switch met and the light on the switch came on, still nothing..
Traced the wire back as far as I could, and then checked from there (checking for broken wire) nothing..
Does anyone have a wiring diagram for the rear window heater?
Been looking for a relay but cannot find one, does one exist for this?
Any ideas on what else I can try?
Thanks
Unfortunately not.
Thanks
