Hi on removing the rear head  panel i have found that i have no tweeters , they are i believe 2 ohms and the connector for the feed is a 4 way connector in the offside part of the panel ,does anyone know which wires are for each speaker. I know that 2 ohm speakers are rare but have seen some very small surface mounted tweeters on the maplins website that are 4 ohms as these are very small you could buy 2 packs and use a pair in parallel to make 2 ohms , two mounted in the roof area  and two mounted near the rear light cluster area.I have fitted a rear cover but this cuts out the sound quite a lot from the rear speakers but the base is still audible the mounting of these tweeters would give quite a good sound , any comments .
mark.s
					mark.s
