Anyone know if the adjustable shocks are actuated via a relay - and if so - where I might find it?
Recently swapped back to adjustables and usually have on Soft setting. Today went up M5 and switched to Hard (as advised by manual) in case of any rapid lane changes I presume and when switched off afterwards, the light stayed on.
Switch works fine - shocks all actuate properly - but when switched off, the warning light slowly comes on - until almost as bright as if switched on. Sometimes a few flicks will knock it of again - but a few mins later its back on.
Can anyone save me a bit of investigation time here?
Kev
Kev
