As the oil cooler lines leave your gearbox, do you have a temp sensor on one of them, and if so, does the loom it is connected to have a removable section?
The gearbox has clearly been taken out of mine at some point and only half put back in. There is a 2 pin connector on the sensor, and a 2 pin plug on the loom, but there is no way it will reach, even if the loom is re routed (and I'm fairly certain it is currently in the right place)
I'm quite stumped by this! And I'm struggling to find another 2.7 to compare against. It's a 1997 model srs limited if anyone is wondering.
Any info (or pics!) greatly appreciated!
Steve
Steve
