I have a dc amp/volt meter if you need to check alternator output/battery voltage.
Rzn 185 battery
Mine is doing the same at the moment, (The 2001 truck) there's a slow drain on the battery if the truck isn't used for a couple of days. Bought a new battery and still the same thing happening.Originally posted by BioHazard View PostYep it's not holding a charge very well.....
I suspect the alarm as the battery seems to hold it's charge for longer if I don't arm the alarm and just use the central locking via the key instead of the remote.
AH i am not alone then ...... But it's the same with or without alarmOriginally posted by BUSHWHACKER View PostMine is doing the same at the moment, (The 2001 truck) there's a slow drain on the battery if the truck isn't used for a couple of days. Bought a new battery and still the same thing happening.
I suspect the alarm as the battery seems to hold it's charge for longer if I don't arm the alarm and just use the central locking via the key instead of the remote.' You've arrived on a rather special night. It's one of the master's affairs.'
Originally posted by Thrifty"Describe in single words only the good things that come into your mind about... your mother
It's a question for identifying Replicants in Bladerunner' You've arrived on a rather special night. It's one of the master's affairs.'
