Can anyone tell where to purchase a V6 replacement exhaust? Can not find one anywhere.
New Exhaust
How much do you need, if its from the cat back, a 2.4TD system is almost the same and same size pipe, you just have to alter the front piece a little. (needs shortening to meet the cat) It actually sounds nicer, as the don't get the little resonator box on the tailpipe. Or if you want to increase the pipe dia cat back, fit the 3.0TD system.Originally posted by kenzCan anyone tell where to purchase a V6 replacement exhaust? Can not find one anywhere.
If you need the cat as well, Probably Toyota unless you have a custom system made, which will probably be cheaper.
Thanks TonyN,Originally posted by TonyNHow much do you need, if its from the cat back, a 2.4TD system is almost the same and same size pipe, you just have to alter the front piece a little. (needs shortening to meet the cat) It actually sounds nicer, as the don't get the little resonator box on the tailpipe. Or if you want to increase the pipe dia cat back, fit the 3.0TD system.
Decided to get a custom exhaust fitted by Longlife Exhausts (Leeds) guaranteed for life!!!! with letterbox tailpipe, see attached photos.Last edited by kenz; 27 September 2005, 18:40.
Looks nice - whats the sound like?Originally posted by kenzThanks TonyN,
Decided to get a custom exhaust fitted by Longlife Exhausts (Leeds) guaranteed for life!!!! with letterbox tailpipe, see attached photos.Tim
Yeeees ! agreed , it looks high quality spec...now some would say there is need for all "kit" below rear fender level to be re-located for greater ground clearance when off-roadin, but why hide this zorst tail section - its a beaut IMHO...thanks for the piccy, will probably generate lots of enquiries...Originally posted by kenzDecided to get a custom exhaust fitted by Longlife Exhausts (Leeds) guaranteed for life!!!! with letterbox tailpipe, see attached photos.
