In the mornings when I start my Surf a significant amount of blue white smoke comes out of the exhaust and then disappears. Is this something to be concerned about or is it normal?
Smoke?
Sounds like your valveseals are gone. How many miles?
Small change that its the HG, but generaly that's white smoke.
I would definatly have the radiator and heads pressure checked.
My HG's went twice. Very common problem with the 3VZ-E. Mine failed both times at the cilinder where the cross-over pipe attaches to the left exhaust manifold.
Good luck with that engine.
