there was an interesting topic covered in one of the uzfe forums on facebook,recently.
several trucks were running with low MPG returns,and after a lot of work,the trouble was traced to electrical issues.all of the trucks,in question,had modified manifolds or looms,or o2 sensor replacements.odd thing was,it reminded me of my physic's o'level exam,as it was to do with ''ohm's law''
if the o2 sensor wires are lengthened, or cut,or replacement ,cheap o2 sensors used,it increased the resistance of the wires,leading to the ECU believing that the engine was running lean,and hence ,increased the ratio. sadly,expensive toyota o2 sensors,costing a small fortune,and stock loom configurations,were the only answer,but put the MPG back to the 25mpg region.
i have replaced all electrical components on my engine,just for peace of mind,and had to get the dizzy caps from the USA, the rest was either ebay, or Japan.the loom has the original o2 sensor wires,untouched,and i have the stock o2 sensors,which have been refurbed,thoroughly .hope this see's me right.
