Lexurf X Update 4
  • Lexurf X Update 4
    Electrical:-
    http://s743.photobucket.com/user/Per...ary/Electrical
    Took glovebox out and relays and wiring fell down – not clipped up/fastened/supported in anyway.
    Strip connectors used in places and also on electrics under the front seats! Some not insulated either.
    Supply cable for electric seats too short and doesn’t tuck away behind trim – keep catching it with leg.
    Oil sender wire in engine bay just loose, not protected.
    Original water temp & oil temp gauges in dash not connected – “ didn’t do these as fitted the auxillary ones in centre console for you “. Surely 2 gauges better than one!
    No loom grommet in bulkhead.
    Ecu fitted into kick panel – not fixed and no cushioning.
    http://www.hiluxsurf.co.uk/showthread.php?t=70996
    Engine/Gearbox:-
    http://s743.photobucket.com/user/Per...gine%20Gearbox
    Gearbox mounting bolts not tightened up.
    Gearbox crossmember bolts not tightened up.
    Engine mounting bolt not fully threaded in – wouldn’t tighten in – removed and can see why – holes aren’t aligned.
