Say hello to my little friend!
  • zem_41
    replied
    Just a pic of how the engine is resting at the mo.
    Leave a comment:
  • zem_41
    replied
    Here u can c the handbrake lever fouling the transfer case untill I lowered it, now it just about clears.
    Leave a comment:
  • zem_41
    replied
    Here's the left side
    Leave a comment:
  • zem_41
    replied
    Here u can c the position of the zorst flanges, they look pretty similar position.
    Leave a comment:
  • zem_41
    replied
    So once I dropped it down approx 10mm the shaft now has more clearance which will increase when I drop the engine down onto the mounts I hope.
    Leave a comment:
  • zem_41
    replied
    So this is where I had the t/c, it was too high here as when I bolted the prop shaft up it was against the sub frame.
    Leave a comment:
  • zem_41
    replied
    Have plenty of clearance on the left side and the bulkhead.
    Leave a comment:
  • zem_41
    replied
    So here you can see how close the cam bung is from the handbrake pulley, it's about 3-4mm so I may have to pull it forward slightly. Looking at the pic it may b even closer than that.
    Leave a comment:
  • zem_41
    replied
    As you can see in the last pic it's pretty close!
    But on the other side I'm also very close to the oil filter, I will turn the bolt around so I can just about change the oil filter.
    Leave a comment:
  • zem_41
    replied
    Update
    So here I have the clearance between the headers and the steering column, it has to be somewhere near here because of the oil filter.
    Leave a comment:
  • zem_41
    replied
    Update
    So today I trial fitted the engine. I think I have it somewhere near but there are a few clearance issues.
    In this pic you can see I have the sump resting in a bit of 3/4 inch ply, it's not got the whole weight on there just balancing. This is resting on the steering bar.
    Leave a comment:
  • zem_41
    replied
    This is how and where it sits inside
    Leave a comment:
  • zem_41
    replied
    And as it would sit on bottom of tank
    Leave a comment:
  • zem_41
    replied
    And as it would sit in bottom of tank
    Leave a comment:
  • zem_41
    replied
    Not sure if this filter is the right one?
    Checked the pic in dannyboys thread and his seems to be more of a 90 Degree angle where as mine is more of a 45 degree.
    So when mine is on the bottom it folds the filter up slightly?
    Am I just not seein this right?
    Leave a comment:
