Hi All, after the engine mounts split when i was off roading in bala last month, I decided to change the design. Originally it was a once piece mount that went straight to from the engine to the original surf mount. As you can see the sharp angle the bracket hit the mount, it put stress on the rubber mount in a shearing action and that’s what happened to it a few weeks ago, the rubber sheared.
So after a bit of pencil scribbling I have come up with the below and seems to be a better solution and the load on the rubber mount seems to be more uniform and more in compression, which is what it should be.
Not there is any hard or fast rule about this bit of the design for the conversion, just though would share the love
