Just to clarify,the K's racing kit(from Thailand) doesnt come with a ring gear on the flywheel.The standard one has to be removed from the flex plate and welded on!
Also all R series gearboxes have the same bellhousing to gearbox bolt pattern,and all W series and G series boxes have the same bellhousing to gearbox bolt pattern ie a w57 bellhousing will fit on a g52 gearbox
Hope you don't mind me coming in at this stage, but although registered on here since August last year and looking at a lot of your posts regularly, this is the first time that I have made contact as a newbe.
