Looks great as per... can't wait til it's ready for the test run
Lexurf VIII
cured with blowtorch
I did the wifes exhaust down pipes on her motorbike with that stuff and i must say its lasted well, little dull right against the clamp, but the rest is fine.Remember arrows are silent.....................
Hey Vince, I see the down pipes from the manifolds start off in 2 1/2"
and then reduce to 2". Is there any paticular reason for this?
Does the V8 like a bit of back pressure?
I ask because a local custom exhaust place has given me a very good price
on a 2 1/2" stainless system.Still on a mission.
Originally posted by Bazcam View PostHey Vince, I see the down pipes from the manifolds start off in 2 1/2"
2.5" will be fine, but ask then to install an 'X' pipe as close to the downpipes as possible, or 'two 'Y' pipes, so that the downpipes merge into a single 2.5" pipe then split into two again at the back.
By merging the two banks of cylinders smooths out the exhaust flow and gives a little more power at the same time reducing the noise level at high RPMs.
The V8 doesn't need any back pressure.
Forgot to add, don't go bigger than 2.5" or you'll lose low end torque.
I went for 3" on mine from the downpipes all the way to the back and had to rev the engine quite high to get any oomph out of it.
I fitted 2.25" to Lexurf III and that seemed to be the optimum size for maximum torque/horsepower, I fit 2" now as it's easier/cheaper to find parts/tube.
Originally posted by BUSHWHACKER View PostThe V8 doesn't need any back pressure.Originally posted by BUSHWHACKER View PostForgot to add, don't go bigger than 2.5" or you'll lose low end torque.
And if "open headers" are the optimum for V8's then why would a larger than standard exhaust system be detrimental?
Or is it because you would you need to alter the tune for the larger pipes?"B.A." Baracus: "Talk to me, talk sense so I can talk back. Not all this jibberjabber like breaking the peace and all that."
www.johnthebuilder.info
It's all to do with Scavenging, Harmonics and Energy waves.
Inertial scavenging and wave scavenging are different phenomena but both
impact exhaust system efficiency and affect one another. Scavenging is simply gas extraction. These two scavenging effects are directly influenced by pipe diameter, length, shape and the thermal properties of the pipe material (stainless, mild steel, thermal coatings, etc.). When the exhaust valve opens, two things immediately happen. An energy wave, or pulse, is created from the rapidly expanding combustion gases. The wave enters the exhaust pipe traveling outward at a nominal speed of 1,300 - 1,700 feet per second (this speed varies depending on engine design, modifications, etc., and is therefore stated as a "nominal" velocity). This wave is pure energy, similar to a shock wave from an explosion. Simultaneous with the energy wave, the spent combustion gases also enter the exhaust pipe and travel outward more slowly at 150 - 300 feet per second nominal (maximum power is usually made with gas velocities between 240 and 300 feet per second). Since the energy wave is moving about 5 times faster than the exhaust gases, it will get where it is going faster than the gases. When the outbound energy wave encounters a lower pressure area such as a second or larger diameter section of pipe, the muffler or the ambient atmosphere, a reversion wave (a reversed or mirrored wave) is reflected back toward the exhaust valve without significant loss of velocity.
Hmmm, think I've read that before somewhere....
Nice to see you've changed you viewpoint on H/X/kiss pipes now!"B.A." Baracus: "Talk to me, talk sense so I can talk back. Not all this jibberjabber like breaking the peace and all that."
