Lexurf VII
Originally posted by Vultch View PostJust out of curiosity, what are the bhp and torque figures for these beasts
All you'll ever need to know about them can be found here.....
http://www.lexls.com/info/
Leave a comment:
Leave a comment:
just a tip from experience vince - i wouldn't clear coat it, oil and heat under the bonnet will make it yellow pretty quick and it might peel off.
its warm and dry under there so a tube of solvol or belgum ally will keep it shiny with 10 mins work once a month. the oil mist will stop the alloy tarnishing.
i clear coated the covers on my gt and they only lasted 2 months, ended up re-polishing and its a pain to get all the clear coat off.
Leave a comment:
It looks acceptable...Originally posted by BUSHWHACKER View PostWhat do you think?
It looks much better in the flesh, can't get a good enough photo of it to do it justice.
Awesome. Surely they can't keep getting better!
Leave a comment:
Originally posted by gbv2 View PostThis is looking awesome Vince so far
I will take great pleasure in maintaining all the hard work you are doing with this build. I'm going to have to order myself some sort of polishing kit to keep on top of it. Any suggestions on what to look for?
Jesus! Just seen them new pics above. Unbelievable
Once it's all polished/coloured, I'll clear coat it all to keep it shiny. Then all you need to do is spray it all over with WD40 and wipe with a cloth.
Leave a comment:
Leave a comment:
What do you think?
The throttle body is going to be the hardest part to polish, as it's not going to be red like the other bits.
Leave a comment:
ditto..
polished is going to look immense!! bl00dy hard graft tho, fair do's
Leave a comment:
The ones I cut were 4"x5" if I remember correct, also did a few egr blanks-the one for the plenum chamber (never got the dims for the others) and some plates with holes matching the bolt pattern on the transfer box mount.
Just let me know where to send them (perhaps have to swap addresses through PM via Lextreme or summat, unless I've missed how to Pm on here
Leave a comment:
I have a fuel pump here, it's in a big box of bits destined for Ebay!Originally posted by scuba_diver View PostI got sorted in the end, had to buy one as it was holding up my project.
I cut a few things for you but if you have some updated dimensions then that's not a problem, I can scrap 'em and cut some more as it's only stuff that'll go in the scrap anyway.
If you still have the latest Lexus do you think you could put the fuel pump to one side for me as I could do with a spare, mine has been a little temperamental??
Re: the plates, all I need is a load roughly the size of the plate that bolts to the engine block. I'm trying something different this time so I can make a few mounts in advance.
Leave a comment:
Leave a comment:
