as the title need a good /engine / ecu diagram to include the clocks as well , thanks in advance terry snailpaceracing@btconnect.com
lexus ls400 wiring diagram
couldnt find any wiring diagrams on there?Originally posted by BUSHWHACKER View PostProbably get all you'll need from here......
http://www.smiffies-soarer-sanctuary.com/parts.htmlJAP4X4PART ¬ THE BIGGEST SURF BREAKER IN THE UK ¬
no worries thats what i thought, do you tailor your own looms out of the original lexus loom , this is what i had planned , i was going to cut the rest away still keeping it in the car so can test that everything is still working ok, once i have just the engine and dash loom all seperate its all ready to remove , what do you think?Originally posted by BUSHWHACKER View Postoops, I read your original post as you were looking for an engine, ECU and dash clocks.JAP4X4PART ¬ THE BIGGEST SURF BREAKER IN THE UK ¬
Originally posted by lord lucan View Postno worries thats what i thought, do you tailor your own looms out of the original lexus loom , this is what i had planned , i was going to cut the rest away still keeping it in the car so can test that everything is still working ok, once i have just the engine and dash loom all seperate its all ready to remove , what do you think?
I'll PM you the wiring diagram that'll get the engine started.
What year V8 do you have?
this is the wiring from the FSM for 1990 - 1994 LS400 lexus think is this what you are after i have them in PDF from and will email you them if you like. they are accurate the colouring of the wiring was pretty spot in. i will have to dig out the wiring connector blocks and locations but i think the 3 main ones are IH1-3 which are near the ECU in the lexus
this is the master diagram only really need the left hand part as the right is the wiring within the engine
Last edited by dannyboy77; 12 October 2010, 08:33.http://www.hiluxsurf.co.uk/showthread.php?t=55797
hi dan i know its a bit late but can you email the diagrams again (cant find were they went ) pretty please,thanks to jap4x4parts@live.co.uk TerryOriginally posted by dannyboy77 View Postthis is the wiring from the FSM for 1990 - 1994 LS400 lexus think is this what you are after i have them in PDF from and will email you them if you like. they are accurate the colouring of the wiring was pretty spot in. i will have to dig out the wiring connector blocks and locations but i think the 3 main ones are IH1-3 which are near the ECU in the lexus
What year?
I pulled my hair out finding "experts" that didn't cater for the VVTi.
Edit just saw you answered it... all my stuff is VVTi
More Tyres.
More Engine.
2.4 definitely going to be turned into a toy now... Looking into reversing camera for 3.0
