Hello all,
I live in the US and I am attempting to swap a 1kz-te into my 2001 Toyota Tacoma. I imported the motor from Japan but I foolishly got one from a Hiace Regius and the oil pan hits the front differential. From looking at the various diagrams, I think what I need is a pan from a KZN185.
Here is my Hiace pan:
https://www.megazip.net/zapchasti-dl...599117-4599117
Here is my original gasser pan:
https://www.megazip.net/zapchasti-dl...cylinder-block
And here is the 185:
Does the 185 pan look almost the same as the Tacoma to you all?
Also, my most recent idea is to just rotate my Hiace pan 180 degrees. Does anyone think that would work?
Thanks so much!
Thanks so much!
