auto box stripdown ( lost drive )
  • auto box stripdown ( lost drive )
    I stripped the box on my 94 3.0TD, It was OK to take out but it would have been easier if I took off the diff first, that is the heavy bit.
    I found everything in the box in good condition but the bush on the pump was scored up. I suspect the problem is with the torque converter / pump.
    I vidioed the strip down. Getting spares will be the biggest problem.
    I have seen some used boxes for sale but I need to be sure they are for my car. Can anyone tell me if the 2.4td box is the same ?.
    The trans ID on the Vin plate on the bulkhead under the bonnet is A343F and the plate on the right hand side of the gearbox is:
    Model No: 30-43LE Serial No: 94H E 03940 Can someone check the ID numbers on their 2.4td
    Thanks
