Towing capacity
  • Towing capacity
    Hi, I own a '97 hilux surf SSR 3.0 Turbo Diesel, do anyone know if I can tow a 7000 lbs boat? I can't find the towing capacity spec anywhere.
    thanks
    thanks
    Not a chance, try a search on the forum as this topic has been discussed several times.
    Maurice
      thanks
      Think you need a Landcruiser Amazon or a Nissan Patrol for that. Both of them have a 3500lb towing limit however I have heard of them towing over 8000lbs.
      The Surf would probably pull the 7000lbs but because it is not really heavy enough for that weight it would be a real handful to tow at anything over walking pace.
        thanks
        Whats that in Kilos
          Originally posted by marky
          Whats that in Kilos
          7000lbs = APPROX 3182kgs
          Way too much, if i remember correctly my '96 was weighed at 1960kgs.
          Maurice
            A very heavy boat then White water jetboat in the ANDES ??
              LC and Patrols can tow 3500kgs yes but i think the LC engines are rated to around 6000kgs on private land without any problems.
              Tim
                or in Peru.
                  Originally posted by TonyN
                  or in Peru.
                  could probably tow peru
                  tim
                  Tim
                    conversion of weight
                    7000Lbs equates to 3.175 Tonnes
                    A Landrover can tow 4 Tonnes legally - hope this helps....probably not though !
                      Surfs are approx 4000lbs or 2 metric tonne (2000lbs = 1 tonne)..
                      Land Crusier Amazon,Isuzu Rodeo [new pickup] and the New Patrolare vehicles I know of that can pull 3500kg >7000lbs]...which I believe is the max legal limit for cars?
                      Gaz
                        As much as I hate to admit it, a Discovery can tow 3.5 tonnes as standard and 7.5 tonnes with a slave brake system fitted. Looked in to it years ago when I was a disco owner.
                        Not sure I would like to try it though!
                          Towing rule of thumb for any vehicle is 85% of it's kerbside weight, maybe an exception with some of the heavier 4 x 4's. If new to towing I'd stick to it, more experienced can tow higher ratios to kerb weight but not recommended.
                          Nev
                          (new to Toyota Surf's)
                          Ex 4 x 4 instructor (Civil and Military)
                          UKAHFT Organiser
                          [URL=http://www.ukahft.org.uk]www.ukahft.org.uk[/URL]
                            Negative ..
                            thanks
                            Nooooooooooooooooooooooooooooo ..
