I have the chance of a set of 6 stud 4x4 wheels , what is the best way to measure them to see if the fit my 3rd gen surf , I have measured the hole centres and they appear correct , is there anything else I need to measure , help would be much appreciated
Alloy advice needed asap
In that case and provided, as Growler said, they are not 15" they will fit. Only other issue could be offset. Surf wheels are negative offset, I think anything positive could give rubbing issues, but you will get away with more negative, without hitting the arches with your rubber.Сви можемо
