mine be the same
at 30 i am doing28
at 40 i am doing 38
at 50 60 70 more or less the same
so if you stick to speedo reading tou will always
be just under the limit
an if you doing 80/90 keep yer eyes open
no as i ever go that fast
30mph actual reads 25
35mph actual reads 30
and so on, I'm guessing that the needle has been put on incorrectly, Is there a correct procedure to removing and reinstalling it?
And are you using a phone to give you GPS speed and comparing that to the speedo? They are pretty accurate, moreso than a dash speedo, and get more accurate the faster you go, as long as the road is straight (IIRC they refresh every 10 metres you travel).
